Rear window wiper | Ford Explorer Forums
Rear window wiper
Terberta
Burlington,Iowa
2015 Explorer XLT
I think I finally got it. To keep the wiper from stopping or just not working half the time unplug the safety switch right above the latch. Just remove the cover cap and you can see it. This is so you can't use the wiper when the window io open. To keep the wiper on the glass tighter so you don't have a large area where it won't make contact and wipe clean I removed the whole cargo door inner cover and adjusted the motor by putting 4 washers to the bottom screw of the motor where it mounts to the brace that holds it. I also put a couple washers on the top screw of the bracket itself. All works great now.
