TxPlates
- October 3, 2004
- Marble Falls, TX
- 2001 "Rock Trac"
I have a 2002 Sport Trac 4x4. I just installed lockers in the front and rear. After I got it back together, now the ABS light comes on after you hit 15 mph. Once you turn the truck off it's off and won't come back on till after it hits 15.
I've checked the connections I can see, nothing is cut. All connections are together as far as I can see. I had it hooked up to read the code, but since you can start the reader while the truck is running, you have to turn it off, hook the computer and back on, so the light is not on and the machine says the computer isn't storing any codes.
Any ideas?
Any ideas?
