Hopefully the old ones will come off and can be re-used. It's so typical for a dealer to charge 100 times what a part should cost.Last I saw, Ford wanted something like $200 for the lower bolt and but. If yours is shot due to rust, I'd hit up a wrecking yard.
Any suggestions about where to get the torque settings for the bolts? I hate to get that wrong on a suspension part.
The video from A1 auto says 20-25lbs for the 3 top bolts. It says 110lbs for the bolt from the LCA to the wheel knuckle and the two bolts that hold the LCA to the frame. It doesn't say anything about the torque for the bolt that holds the bottom of the strut to the LCA. I hope I don't have to loosen the LCA from the frame since I think it would be hard to get it back in the right place without a lift.
LMHmedchem
Thanks for the data, that will be very helpful to know.top 3 bolts - 22 ft lbs
lca to knucke bolt - 111 ft lbs
shock absorber bolt - 184 ft lbs
Do you know off hand where to get them and what the part number is?depending on how rusted the wing nuts, it could separate from the bolt. i think it was around $5-15 for the bolts and nuts (each piece)
LMHmedchem
I checked today and they want $26.30 each for the bolts and another $3 for the wing nuts. Almost $60 for the pair is a bit more than I would like to pay, plus they didn't have them in stock anyway.only stealership item, their parts guy will be able to help you along with the parts diagram. you can even ask a copy of it with torque specs.
Hello,
While doing my rear brakes a while back, I noticed that the coil spring on one of my rear struts was broken. It is the very top coil that is broken, so that side is not down very far at all. I guess that is why I didn't notice.
I am looking at replacing the rear struts but I'm not sure what to get.
This is the first thing I looked at,
Monroe Quick-Strut Complete Strut Assembly ($196)
I presume that I need two of these, one for each side.
I am not married to buying at advance auto. I am surprised that these are not sold as a pair. I tend to use a bit better grade of part when I am doing the work myself, but I'm not opposed to saving a bit if there is something reasonable available that costs less.
I have never done the struts before. The last time I tried, I couldn't get the old ones off. I am also a bit worried about getting the lower controller arm back in the right place if I have to loosen it during replacement. I would probably have a 4 wheel alignment after doing something like this, but I don't know if that is an adjustment that they would normally make.
Any information or suggestions would be appreciated.
LMHmedchem
I already received them from RockAuto. They came yesterday.Not sure if you already bought the struts but call Advanced Auto's 800 # and they will price match RockAuto. At-least they did for me when I just bought my Moog hubs.
I was going to post a picture, but for some reason I can't do that.
LMHmedchem
