Recognizing my limits tonight. p21345 now p2104 and 2111 | Ford Explorer Forums
hlg99
Boston
08 Mounty Premier
2008 Mounty, 4.6 engine, started giving me trouble accelerating and idling ended up with the wrench light and pulled a p2135 code. Cleaned the throttle assembly changed out the TPS and and found that the plug and pig tail where brittle and showing some wire so I replaced that. After reconnecting the battery it will only start in limp made and gives me the 2104 and 2111 codes. I gotta get it towed to the local shop in the morning and let them take a look at it.
That sucks, I hate when I can't figure out these and have to pay $$$.
Did you checks other wires and connections ?
Checked as far as I can, Been working on it after work and the Mrs is starting to get annoyed carting me to work around her own schedule.
I am sure you saw my issues from a year ago:
Yes I did sir, You could say it was a factor.
Picked truck up at the shop today. Burned out motor on the throttle valve, remove and replace.
Next up water pump bearing is whining. Back on the road missus off my case.
