993usmc
- May 14, 2009
- NoVA
- '02 Explorer w/192K
Hi all,
Great forum, and testament to our explorers that I have not had to come back here for a while. My 2002 V-6 XLT Explorer has developed an issue at 192K miles. It left my wife stranded for a bit and was inconveniencing, to say the least.
Here are the steps I did to diagnose the problem of the no-start
-Engine turns over fine (battery strong)
-All proper fuel system fuses are intact
-Fuel pump reset switch in proper position
-Engine is getting spark and air
-No CEL codes
-Checked fuel pressure at the relief valve on the fuel rail= zero
-dropped fuel filter (PIA!), metal shavings inside.
-Attempted to turn over, no fuel delivered toward the fuel filter
So my next guess is the fuel pump, unless you all think I missed something?
The Motorcraft part seems to run about double the price of the aftermarket ones. Is there a good OEM-type replacement pump that you would suggest for my early '02? I would like it to be the whole drop in kit with screen, etc...
Thanks in advance!
Cheers,
Doug
