Regear Rear Axle? | Ford Explorer Forums
Regear Rear Axle?
MrQ
Smokey the clutch is; Missed shift you did
Moderator Emeritus
Location
Humid, Damp, and Hot
Houston, TX
'98 EB, '93 Limited
Hey,
I need some help. Is it possible to regear my rear axel with something like 3.73's? I checked my gearing and I have a lousy 3.07!!:thumbdwn: Ugghh.
Also how would I go about doing it? Do I have to remove the whole axel?
Thanks,
MrQ
If you have 4wd and want to use it you will need to re-gear both axles. 3.73s are fairly common in explorers, it's much simpler and easier to swap the whole axle.
Re gearing axles takes specialized equipment and know-how. Otherwise you'll quickly ruin a new Ring and pinion... check out the How to re-gear axles in the Useful thread forum for lots of info and pics of the process.
