Regearing, need speedo gear? | Ford Explorer Forums
slickemhoundd
Glassboro, southern jersey
1996 Limited 5.0
Im running 3:73's and putting in 4:56's. Im now running a 33" tire and might be slapping in 35's in a couple weeks. Want to know if i should swap the speedo gear or if i should be okay. As of now its off from 35 mph and up going from 1 mph off up to 10 mph off at 80 when reading 70
I like that link, kept me occupied tire shopping! My only question with that chart is it being based off of a jeep trans BUT i believe they arent to far off
It's calculated from a 1:1 ratio, so if you have overdrive these will be higher than what yours reads, but it's still a good guide. I see it as if the rpms are fine on this chart, they'll definitely be fine on my truck with the overdrive.
