BrandonB8
- September 27, 2002
- St. Louis
- 1995 XLT
I am wondering if anyone can help me with a problem I am having with my '95 explorer. My brake warning light came on yesterday mysteriously. It ended up being because of low brake fluid. I disconnected the battery for fifteen minutes hoping it would reset the sensor. When I hooked the battery back up my keyless entry doesn't work or the keypad or the autolock feature. I tried to enter programming mode using the Off-Run 5 or 8 times trick. This did not work. Has this happened to anyone else upon disconnecting the battery. Any help is appreciated. Thank you..
