remote entry problem help please | Ford Explorer Forums
BrandonB8
St. Louis
1995 XLT
I am wondering if anyone can help me with a problem I am having with my '95 explorer. My brake warning light came on yesterday mysteriously. It ended up being because of low brake fluid. I disconnected the battery for fifteen minutes hoping it would reset the sensor. When I hooked the battery back up my keyless entry doesn't work or the keypad or the autolock feature. I tried to enter programming mode using the Off-Run 5 or 8 times trick. This did not work. Has this happened to anyone else upon disconnecting the battery. Any help is appreciated. Thank you..
Just wanted to post explaining the procedure that fixed this problem. I unplugged the module in the driver's side rear compartment. I then disconnected the battery. I reconnected the battery and then plugged the module's connectors back in. The alarm started going off so I entered my code into the keypad. The alarm shut off and the keyless entry and keypad started working again. I hope this helps someone in the future.
you are king BrandonB8, it worked like a charm...
finally keyless entry back in full swing, after almost 6 months...
