Removing 02 tranny | Ford Explorer Forums
Removing 02 tranny
02dubs
leland/ Traveres City, Michigan
02 XLS
I have a 2002 explorer xls that i am removing the tranny on tomorrow. anybody have a how to? I am replacing it with a brand new tranny this week, please send me some links and any help would be GREAT!!!
Thanks Rudy
First disconnect the battery, and the transmission's wiring harness. Drain the transmission, and the transfer case. Remove the driveshaft, and transfer case. Remove the starter, then the torque converter's lock nuts. Remove the catalytic converter, and place a jack underneath the transmission pan. Remove the bellhousing bolts, and the lower rear crossmember where the transmission mount is connected to. Use a prybar to separate the transmission from the engine. Drop the transmission, and the torque converter. It should be a few hour job.
