- December 28, 2010
- Russell, Ontario (Ottawa area)
- 2025 Aviator Reserve 201A
- Callsign
- VE3... grid FN25hg
Welcome to the Forum.Do we really need the front air dam? I'd like to take it off for more front end ground clearance. Would doing so interfere with engine or transmission cooling? Any cons to taking it off?
Do you have the factory installed tow package? If yes, there is an opening in the air dam for cooling purposes. As noted above, the air dam is part of the overall aerodynamics. Some members have removed it and others have trimmed the bottom 'lip'. Any modification of it likely won't affect anything until driving at higher speeds.
Check out this thread I found using the Forum's handy 'Search' feature (upper right); http://www.explorerforum.com/forums...to-trim-lower-fasica-prevent-scraping.336640/
