trucku
- January 25, 2005
- Queens, New York and living in Budd Lake, NJ now.
- 2002 Explorer XLS 4.0 4x4
How to Remove intake manifold SOHC 4.0
You might need to remove your intake manifold to replace the gaskets or get to your injectors.
FIRST. pull your fuel pump relay out while truck is running. Your truck will stop running. This will releave fuel pressure from the rails and injectors.
1) Disconnect your negative cable from your battery.
2) Remove the cover protecting the throttle body and cables.
3) Start disconnecting vacuum lines and electrical connections.
Disconnect these vacuum lines and electrical connections.
You have to remove your Throttle body (4 bolts) to be able to remove a hard line to your EGR.
It is hard to show you were the intake bolts are. Here is the intake off with the bolt pattern. To get to the last 4 bolts towards the firewall you really need to get over the intake. I used a small step ladder and layed across my radiator (i am only 5'6"..lol) to reach. I put an extension on the T30 bit and the bolts came of with very little effort.
To install just do everything in reverse of when you started. It really is easy, just take your time.
When you are done you will have this
Now to remove the fuel rail let me find the pics.
