i dont know how to remove the wax from the black trim, but the next time you wax your truck, put some "back to black" or one of those black trim 'shine-up' products on there before you wax it. when youre done waxing you can go back and just wipe the wax off the black trim. hope this helps for future waxing.
I want to know how this was discovered... kind of like the perst people that made coffee... "hey, if we crush this beans in to tiny grounds, then run hot water through them and filter out the grounds, it will make a good drink with lots of caffiene!"
The only problem I have with Back to Black is that it is sort of runny and doesnt cover all that well. The type of plastic around the door mouldings always seems to disperse it also. I always use whatever prep I used on the vehicle to clean the smooth plastic, swirl remover etc.
