Replace negative battery cable | Ford Explorer Forums
Gary Colburn
Hanahan
1998 Ford explorer xlt
Need help in replacing my negative battery cable. 98 Ford explorer, 4.0 sohc vin - e.
Do you have a more specific question?
Do I remove starter to see where negative cable connects to engine?
Your negative cable is a ground cable. You do NOT have to remove your starter to see where it connects. You should have a negative cable connected already... the one you want to replace.
What is it connected to? Should be frame and/or engine block.
Track your existing cable. It should be heavy gauge wire, like your replacement.
Right, just didn't see when I was under there earlier.
You got this! Good luck.
