replaced MFS then changed headlights know wipers wont turn off | Ford Explorer Forums
BC
98 explorer OHV
I had problems with the headlights not working at all. I went to the junkyard and got a multi function switch and it works. Then had to change the drivers side headlight so I changed that went to try the headlight and the wipers will not turn off the high lo works does not have intermediate stage but it does go from low to high all other function work including washer fluid. Multi function switch worked fine for three days until I just changed the headlight confused.
