KitGames
- October 26, 2013
- Jacksonville, Fl
- 2003 Explorer Sport XLS
Jumped on it when I got up. Plugged my ODBII reader in and connected FORscan and got code P1000. Took a 30 minute drive and reconnected FORscan when I got back and here is the log:
(WARN) [11:29:15.931] Checking COM3...
(OK) [11:29:17.489] Connection to adapter is established on COM3
(OK) [11:29:17.489] Adapter: ELM327 v1.5
(OK) [11:29:18.144] Connection to vehicle is established
(OK) [11:29:31.124] Vehicle: Ford Explorer Sport V6 SOHC 4.0L 2003 MY, VIN: 1FM*********11777
(OK) [11:29:33.005] Found module: OBDII - On Board Diagnostic II
(OK) [11:29:34.637] Found module: PCM - Powertrain Control Module
(WARN) [11:29:35.040] DTCs in PCM: P1000
(OK) [11:29:35.890] Found module: RCM - Restraint Control Module
(OK) [11:29:37.455] Found module: GEM - Generic Electronic Module
(WARN) [11:29:37.932] DTCs in GEM: B1818
(OK) [11:29:38.710] Found module: ABS - Anti-Lock Brake / Traction Control Module
(OK) [11:30:48.715] Disconnected
(WARN) [12:01:54.245] Checking COM3...
(OK) [12:01:55.300] Connection to adapter is established on COM3
(OK) [12:01:55.300] Adapter: ELM327 v1.5
(OK) [12:01:55.903] Connection to vehicle is established
(OK) [12:02:01.158] Vehicle: Ford Explorer Sport V6 SOHC 4.0L 2003 MY, VIN: 1FM*********11777
(OK) [12:02:01.701] Found module: OBDII - On Board Diagnostic II
(OK) [12:02:03.301] Found module: PCM - Powertrain Control Module
(OK) [12:02:04.255] Found module: RCM - Restraint Control Module
(OK) [12:02:05.869] Found module: GEM - Generic Electronic Module
(WARN) [12:02:06.296] DTCs in GEM: B1818
(OK) [12:02:07.101] Found module: ABS - Anti-Lock Brake / Traction Control Module
(OK) [12:02:41.474] Disconnected
Not sure I drove long enough, I thought I noticed some difficulty shifting but the OD Off light didn't come on. Could be my own paranoia though. If this simple thing was all it was I can't thank you guys enough. I'll have to take it for a longer drive this weekend, maybe put it through it's paces just to be sure, but right now I'm feeling very relieved.
I left a note for my brother, I'm afraid I'd kill myself or the car messing around with it. Though I'm not sure we need to do that now? I probably should have followed his order, I let it idle for around 5 minutes while plugging in and turning on Forscan but I started it up without leaving it in the ON position for 10 seconds.
Bobmbx said:Any kind of wire will work; you're just shorting the + and - sides of the cars electrical system together. You could take both leads off the battery and just hold them together; same thing.
DON'T SHORT THE BATTERY TERMINALS! Bad joojoo will happen.
