Replacement blend door question | Ford Explorer Forums
96eb96
Albany, NY
96 EB V6 OHV 4WD
does the dorman replacement blend door fit into the hole on top of the stock airbox? I know it comes with a replacement plate with a hole for the top of the box. I'm going to be replacing a leaking evaporator core, so I might as well swap the door thru the hole. I will probably get a $40 motor too, I hear it creaking every few trips.
