IMHO, buying aftermarket headlights is a waste of money. You most likely won't notice the difference and you'll get the same output from PIAAs than you'll get from generic superwhites. I've seen them both to compare and I didn't notice any difference. If you want brighter lights, buy some aux lights from Hella. They are the best for the price, but if you have money to thorw around then buy some PIAA 520's.
I have a set of piaas.. at first I noticed no difference from my stock lights.. but after I have seen my friends headlights.. I've found that mine are actually much brighter than theirs.
I can however agree with you, unless you get higher wattage halogen replacements, you won't really see a huge difference in brightness. I got a set of 001 solitare driving lights on my guard for that.. they may look alittle small, but they give off some good white light, they really help fill the gap bet. the 2 headlights up front
Also, your best bet would be to find a pair of E code headlight assemblies and sue those with the brighter bulbs. E code lamps are more focused on the ground than the DOT ones. Ford UK should be able to help out on that.
In my experience, I went to my 4X4 shop and to end my uncertaintly about shelling out mega bucks for PIAA headlight replacements, the guy replaced only one light and had me point my X to the wall of their store with the lights on...what a difference. The stock lights shown yellow while the PIAAs were brilliant white.
Originally posted by PLRBEAR Also, your best bet would be to find a pair of E code headlight assemblies and sue those with the brighter bulbs. E code lamps are more focused on the ground than the DOT ones. Ford UK should be able to help out on that.
