Tnashua
- August 20, 2013
- Location
- Oskaloosa, IA
- IA
- 1998 Ford Explorer
I recently discovered that my radiator needs replaced (was cleaning it up in preparation to re-install w/ my overbudget rebuilt engine)... I have a 98 with the 4.0l OHV & a 5 speed. I don't mind having a radiator with the aux. cooler built in- because I may put a power adder on at some point & might use it to cool my oil... I Do Not Want a single core radiator- Needs to be a double [2] core... I prefer to use a reputable brand, but being overbudget- my wife says "go cheap"...
I have searched quite a while & not come up with a definite answer- so I am posting my Q's here (sorry if the answer exists & my inadequate search methods did not reveal it!):
Can anyone tell me the difference between how the 4.0L SOHC radiator, the 5.0L radiator & my 4.0L OHV radiator mount? All the pictures look the same to me. One search suggested that the 5.0 radiator would mount 3/4" further forward... That is about all I turned up.
I am currently pondering the use of the following 2 part numbers: CU2174 & CU1824... The first # is for the SOHC engine while the second is for the 5.0...
Has anyone used one of these (or an interchangeable radiator) on their OHV Explorer? If so- what modifications were needed? If not- what radiator(s) have you used that you were pleased with (just 2 or 3 core radiators please)?
I found one place offering completely aluminum 3 core radiators, but they are no thicker than the 2 cores... Anyone had good luck with a "cheap" all aluminum unit?
Thanks for your input!
