Jim Jermain
- February 20, 2006
- Madison, WI
- 00 XLS
I am replacing the heads on my 2000 4.0 OHV. I have two quick questions. I am reusing the push rods and rocker arm. I am installing then exactly in the same spot as they came out. Do I need to replace the rocker arm bolts? Also I notice a few of the rocker arms are not centered exactly over the valve stem. I tried loosening the rocker arm shaft, but there isn't any side to side adjustment. Is this normal?
Thanks,
Jim
Thanks,
Jim
