scrivyscriv
- June 1, 2008
- Memphis, TN
- 02 Ranger XLT 2WD auto
Can I do that?
I bought the Ex with 98,000 and R12, running cold, and it ran cold for a month, slowly blowing warmer until finally nothing. I converted to 134 and replaced the evap, which had a bad weld at the inlet and was (probably) my original leak point, as well as replaced the dryer and tube, and put on a junkyard compressor & clutch.
Now at 168k, I'm ready to spend a little extra money getting it working, since I work at a shop and have access to shop air and have decent tools.
I've read about converted systems running too high and needing a larger condensor + a cooling fan in front, so I wanted to replace the condensor with one made for 134. Also wanted to have the 134 hi and low switches to keep my system pressures ok.
I just need help being pointed in the right direction. I don't know my way around 2nd gen Ex's cooling systems and what all I would need to replace.
Side question, on a 1st gen, is the small metal cylinder inline on the hose from compressor to condenser a filter? Couldn't ever decide what it did so I left it alone.
Thanks in advance!
Thanks in advance!
