savedsol
- September 28, 2002
- Willard, Ohio
- Ford Explorer 1994
okay gosh darn it!
i have a '94 Explorer with premium sound.
i been pondering and pondering what happened to my sounds after i installed a '97 alphine head unit!
the problem is i'm not getting any sounds out from the speakers at all!
not even static! i'm using a Metra harness that fits the two connections of the factory wiring (harness for premium sound package)! Dead Link Removed
the Alphine head unit does turn on and keeps memory and everything except no sounds from speakerS!
i installed back factory radio and there IS sound!
the way i have my connections for the Alphine harness are:
Pin 1: Dark Blue (have it open because i have no appropiate wire for it to connect to on Alphine harness)
Pin 2: Open
Pin 3: Blk/Grn (have radio ground connected to this)
Pin 4: Open
Pin 5: Open (have it open because i have no appropiate wire for it to connect to on Alphine harness)
Pin 6: Yel/Blk (have ignition power wire on it)
Pin 7: Blk (have it open because alphine only have 1 ground wire on its harness)
Pin 8: Grn/Yel (have memory power connected to this)
and the other terminal socket for the speakers are simple and i know i have them correctly connected)
have i forgetten a step or something??
thanks for any help!!
Pin 2: Open
Pin 4: Open
