BrianDye
I'll have another...
- March 1, 2009
- Monroe, MI
- 2006 XLT
I was changing my front pads today because they started grinding last night, and found that my front tires are both pretty worn on the inside. More than I imagined. I need to replace my balljoints, and/or get an alignment (I have all my new parts inside but I am waiting a few more weeks until I can buy the new wheels and tires to install all that, along with the lift).
My passenger side is severely worn, the cotton or whatever is right under under the rubber is starting to show in a very small line.
I disabled my 4WD/Auto 4x4 awhile back doing the "brown wire mod" so I am only running in RWD. Would this hurt anything to swap on two used front tires? The fronts are more worn than the rears, so I feel like if any damage would happen, something already would've happened. I could be wrong though.
What it seems like is if I was running without the BWM it would think the tires were slipping if they were that far off sized and keep the auto 4x4 engaged which I could see being an issue, but since I have 4x4 disabled (I cant get into 4 high, 4 low or auto. I can spin my rear wheels, in rain I can fishtail, etc) I don't see it causing an issue.
Theres a local place near me that I could get two nice (but used) matching size tires from for probably $30 mounted. I can't order the tires and wheels I want for at least 2 to 3 more weeks, and was hoping to get it all done during my week of shut down at work, in early July. If I can throw on two replacement tires, that would be no issue to wait it out a few weeks.
