replacing u joints | Ford Explorer Forums
replacing u joints
ledgebutta
milford, CT
91 XLT
i just found out that my u joints are shot same thing with my wheel bearings. has anyone replaced the u joints so you can give me some info on how to replace them. and for the wheel bearings am i going to need to get a puller or somthing for the inner bearings. any reply will help thanks.
Check out the U-joint link in my sig for lots of info and pics on replacing them. Also see the Brake diary Lots of info and pics. After removing the rotor you will need to remove the 2 bolts holding the ABS sensor protector in place. See Spindle thread for more info...I would pick up a slide hammer to pull of the spindle. New England weather generally makes the spindle hard to remove.. There are lots of threads on these subjects just look around...
cool thanks alot
i just did this yesterday and it seems like its alot easier than it looks
