Spdrcer34
- March 14, 2002
- Bremerton, WA
- 1992 Explorer XL
I picked up an 92 Navajo with slight front end damage today...they couldn't get it started, after the accident. It wasn't the Fuel Pump Cutoff Switch. So they sold it to me.
I fought for 3 or 4 hours trying to get it started myself. But luckily I have the entire library that IS ExplorerForum.com, and the 1992 Ford Rapair CD...
The EDIS Module on the Core Support was damaged in the accident, causing a No-Spark issue. And once again, I was lucky enough to have a spare (or 3) around to fix it.
So now I have a 1992 Explorer 2WD 4Dr. in the midst of a V8 swap, a 1993 Explorer 4WD 4Dr. with a bad lifter tick and no Oil Pressure. And now I have a 1992 Navajo....
Now that I have the motor running in the Navajo, It's going into the `93. That will happen tomorrow.
The motor that is in the `93 Explorer now will be opened up, and if I can find the problem, I will fix it and put that motor in the Navajo...
...to be continued...
Ryan
Ryan
