Reverse servo problem | Ford Explorer Forums
sean99
Sunnyvale, California
01 Limited 5.0
My reverse servo has a noticeable angle to it when installed.It does not move freely.I did not force it in,the shaft guided it that way.I pushed it in flush and now it does not want to come out.Is this normal or am I in trouble?
Thanks
Ok,I got out and lubed it up better and it slides right in freely.It still does not sit level.One side sits up about 1/4 when flush with the opening.
That's how it is, look closely at the cover and you will notice it is cut the same way...
Thanks for the help.
This is because it engages the band and is pushing slightly in line with the the circumferential (?) aspect of how that all works geometrically. (Did that make any sense?)
