- February 8, 1999
- Wayoutin, Aridzona
- '93 XL '20 ST
- Callsign
- AB7FH
Someone asked me what my radius arms look like. Here is a shot of them in their latest configuration. Things to note, the main tube is welded into the stock bracket, there is a gusset on top between the new tube and the stock bracket, there is a smaller tube below which strenghtens the radius arm, plate steel is used between the two tubes to further stiffen the setup. The rear mount uses bushings from a solid axle Ford. The rear mount was welded to the frame.
Rick Horwitz
Editor
explorer@4x4central.com
www.4x4central.com
Ricks Explorer
Rick Horwitz
Editor
www.4x4central.com
Ricks Explorer
