Right front end right turn noise... | Ford Explorer Forums
roush9799
2016 Ford Explorer XLT
2002 mountaineer V8 AWD ...When I turn the wheel to the right it sounds like possibly a rubbing noise, doesn't matter if I'm going around a curve at 60 or turning in a driveway. No noise when I turn left and none when it's straight. Doesn't take much of a right turn for the noise to start. Also, there's a squeak every 8 seconds or so at about 55-60mph. Maybe from right side too.
I found the right turn noise, must have been something to do with the front brake shield. I pulled on it a bit and it went away. THey just put brakes on it so that explains that. I still have the 6-10 second squeak on the right side at 60mph. Sometimes it sounds like the right front then it sounds like the right rear. The squeak only last about a second but it's every so many seconds.
Well, I did some searching on here. Sounds like I have the a/c compressor chirp. Guess I'll look into that tomorrow since it's dark now.
