nolerice
- December 20, 2014
- 2013 Explorer Limited 4x4
Hopefully someone can help, I'll try to explain this as best as I can. Any information is much appreciated!
I have a 2013 Ford Explorer and I've noticed that when I accelerate, at the top of the RPM range, right before it shifts, there is a "ringing" noise. Not sure where it's coming from (seems to be coming from engine, under car) but it only happens when the gas is pressed and the car is accelerating. If i'm just cruising with the gas pedal pressed but driving at a steady RPM, it doesn't happen. If I accelerate, hear the noise, then let off the gas pedal, it stops. It's not a whine or squeal...it's a high pitched ringing noise. It's not extremely loud, probably only noticeable to me or if it's pointed out to someone.
I'm not sure if this was occurring before I installed the K&N cold air intake, I noticed it at some point afterwards, but maybe it's a noise that was masked by the stock air intake?
Thanks for reading and again, I appreciate any help that can be provided. This may not be a big issue but I wanted to see if this has happened to anyone.
Thanks!
Thanks!
