kam327
- March 13, 2012
- Tampa, FL
- '22 Limited
I have excess road vibrations (not tire wobble) coming through the steering wheel, pedals and floorboards. Definitely something loose down there. I had the front suspension checked out by a tire place a few months ago and they found nothing loose or excessively worn. So I probably just have to start replacing bushings or even parts until the problem is solved.
Can you suspension experts chime in with the most likely culprits in the order of their liklihood in causing the vibration (and therefore defining the order I should replace them in)? I hope like hell it has nothing to do with the steering system.
'06 V8 with 60k miles. The Bridgestone H/T's are getting close to replacement time. I haven't taken care of them like I should. But this is not your typical speed-related tire vibration. Definitely feels like a loose suspension problem.
Thanks!
Thanks!
