Rockville RV 10.2A Subs Questions | Ford Explorer Forums
North Carolina
2006 Explorer
When y'all got your Subs did you replace your factory speakers? Or.... If so how do you take panel to get to the speaker? Also where did y'all put your amplifier? I was thinking under my second row seats
If you're factory speakers sound ok to you, leave them be.
The biggest sound upgrade is the headunit, then go from there.
All you're adding is bass into the system by putting in a subwoofer, it depends what you're aiming for.
Go with a new headunit and a subwoofer, then see how you like it and go from there.
Amp location and sub location vary. Usually a box behind the seats with amp screwed onto it, or a sub hidden in the rear right panel.
