Rob_E
- November 30, 2007
- Charleston, SC
- '02 Mountaineer V8 AWD
Ok, so I've scoured this forum and I just can't figure it out.
I'm a very amateur diy mechanic, but I tend to be able to figure things out pretty easily (i.e. I've never had to get anything towed after trying to fix it).
After my 02 4.6 mounty warms up, it idles roughly when stopping at a light around 600rpm, and I'm getting some hesitation intermittently around 50mph.
I've done the following in the last week with a few days between each:
Plugs - Autolite platinum
Fuel Filter (well overdue) - Purolator
Air Filter - STP and cleaned MAF sensor. That was this afternoon.
I disconnected the battery to reset the code today. Ran it about 5 miles at low and high speed, but still the same problem. It hasn't thrown a code after the reset, but I assume it will. Autozone read it but it was just generic (1151... I think. I can't remember).
None have these have improved anything very much, besides the normal improvements of changing each of these things out. I'm still also only showing around 13mpg and she's still running rough.
Oh, and it's not dry rotted vacuum hose problem. I fixed that (for $8 thanks to this awesome forum) about 6 months ago.
I suppose the PCV would be the next step, although I'm not sure where it's located. I can't find much about it on this site.
Any ideas would be greatly appreciated. She has about 117k miles on her. I've also been running Techron for 2 tanks, and I put a treatment of Lucas through on the last one.
