Zatko
- October 13, 2011
- 2004 Ford Explorer XLT
First thing: I am not great with cars. My knowledge is limited, so please forgive me if I leave anything out that is important (and let me know!).
I have a 2004 ford explorer, v6 4.0, 2WD, with almost 100,000 miles.
After being a complete dolt and riding for over 6 hours (300+ miles) with overheating problems, I have had a laundry list of problems. Luckily, it seems I taken care of most of them: my thermostat casing cracked, along with shorting my temperature sensor, so I went ahead and replaced those. Spark plugs and wires have been replaced. Recently replaced the thermostat after a pretty decent radiator flush. After all this was done, my check engine light went off, as did my check gauge light. So no more overheating. Even the rough idle was diminished, but still there. I thought all was well.
Until today. My check engine light came back on (and with a vengeance - it's blinking now) and the rough idle is even worse. The engine is visibly shaking. I can take pics and a video if necessary.
I have had a diagnostic run by Ford prior to any of the repairs I mentioned. They said I had a possible cracked/blown head gasket, but obviously they won't know until they open her up. I'm trying to avoid that, so I wanted to take care of every other aspect first. Note: there is no mixing of water/coolant with gas, so I do not suspect a cracked block.
I have read that the rough idle could be due to a computer module (which one? I have no idea) needing recalibrating. After that, I read that it could be due to a vacuum leak between the upper and lower manifold halves, so some o-rings might need replacing. And one other thing I read was that it could be due to the PCV valve being melted/collapsed, causing some sort of obstruction. Honestly, I have no idea about any of these things. This was only from simply browsing some websites (mainly this one). I figured those were my 3 best options.
So I am going to bring her over to my buddy who has an OBD II reader tomorrow or on Saturday, and hopefully this should isolate my problem. If it doesn't, I am hoping that a few of you have some suggestions that may help me out.
Like I said before, I'm quite ignorant to many things auto-related, but I'm learning. Be gentle.
EDIT: I forgot to mention I have had some oddball problems with my AC/heat. It sounds like there are leaves somewhere in the system. When the AC is on, occasionally it will sound like leaves are rustling around (particularly around the passenger side airbag area), but it won't last long. The AC usually works no problem, but when the sound comes up, it doesn't work as well (i.e., the fan seems to have less strength), but then quickly fixes itself. I noticed that the heat wouldn't come through the air vents when I was having my overheating problem (I wanted to cool the car off so I turned the heat on). I don't know if the two are related, but I would imagine they are. The heat problem only happened once, and the AC problem has happened quite a few times.
