dvishloff
- March 19, 2006
- Melfort, Saskatchewan
- '01 Sport
Here we go:
This is a 2001 Explorer sport 4x4, ~110k on it.
It doesn't idle rough when first started but does start to idle rough after it warms up a bit. Also, there is a unique smell once you stop driving. Sometimes you notice it in the cab, other times not. No white out the exhaust.
I am getting 6 codes as follows:
P0302 - Cylinder 2 misfire detected
P0135 - H02S-11 (Bank 1 Sensor 1) heater circuit malfunction
P1401 - Differential Pressure Feedback EGR Circuit High Input
P1130 - Lack of H02S11 Switches - Fuel trim at limit
P1131 - Lack of H02S11 Switches - Sensor indicates lean
P1132 - Lack of H02S11 Switches - Sensor indicates rich
I will be changing the spark plugs & wires this weekend (misfire #2). Will check if there is a blown fuse for the o2 sensor heater (P0135) if that doesn't work will buy a new front o2 sensor passenger side. Also sounds like I may need to change the DPFE sensor, but will try cleaning the MAF sensor first (read somewhere that a dirty MAF sensor may be an issue).
My question is this: If/When I get through all of this, what's next? #2 injector? Coil pack?
Thanks for any and all advice!
