rough running | Ford Explorer Forums
rough running
Jeff352
West Jordan, Utah
2000 XLT
I have a 6 cyl SOHC XLT. I was driving to work last week when out of the blue the engine cut out. The engine would crank, but not run. After towing it home I checked fuel pressure - sure enough, no fuel pressure. Replaced the fuel pump and got 65 PSI on the pressure. Started the engine, but it ran so rough and noisy that I could not idle the engine, but could keep it running. I then got error code p0351 and p0352. So I checked the ignition coil and sure enough it was out of spec. Replaced the ignition coil and it runs smoother and holds an idle. It is still rough idling and running so I checked plugs and wires. things are fine there. I get no error codes now. Where do I go from here to get the engine running smooth again?
Jeff
Have you tried dicconnecting the battery for about 15min so the computer can reset after the changes you made?
