gtyates
- September 24, 2002
- Location
- Tennessee
- Goodlettsville Tennessee
- '09 Sport Trac, '21 Explo
Recently I made a posting about an idle/rpm issue. The idle issue is basically resolved after a gasket leak was found at the egr inlet tube into the air intake. But I have a more perplexing issue that so far no one has been able to resolve. Basically what is happening is when I left my foot off of the accelerator (such as cruising down a hill) I get an immediate drop in rpm's to about 1000 on the tach, followed by an immediate attempt to increase rpm's on its own where it should be (say @ 45 mph tach is around 1600-1700) As the rpms attempt to increase there is an actual surge (ranges 200-300 on the tach) before I either push the accelerator to continue driving or press the brakes to stop for a red light, etc.. Either situation will put the truck back on steady rpm's. The shop I use has hooked it up to their monitors twice and nothing shows as a problem, even for a split second. Mechanic felt it when he drove it, but can't find it. I have replaced the MAF, IAC, and Air Charge Sensors, all with Motorcraft parts, but this has not resolved the issue. Also fuel pressure is perfect. Any ideas? Could the TPS be doing this but the "blip" is so short the monitor does nto pick it up? No CEL is present. Truck has the OHV engine with 111k miles. Ambient temp does not impact this issue.
