hansvdweerd
- November 22, 2009
- Vlaardingen, The Netherlands
- '98 XLT (LPG conversion)
Hello all!
Since about two months I have noticed that at a cold start my Ex idles a bit high in 'Park'. It also seems to pull a bit more when I drive off. This however is only for the first 50 meters or so. When you turn off the engine immediately and crank it again it doesn't 'stick'. This issue is present only once in a while... (a few times a month?). I drive my Ex daily. So most of the time it's fine. Otherwise I have no issues with the car.
The engine doesn't surge at all (idle is stable). About two months ago, when I think about it, I did have a DTC concerning the TPS (that the signal was out of range, I think). This didn't however cause the CEL to appear. After that I frequently scanned for DTC, but there were no codes.
Last February I replaced the upper and lower intake manifold gaskets and also the IAC-valve. I also checked for other vacuum leaks. A few months ago I replaced the stock airfilter for a K&N filter (no mods to the airbox, except last week when I removed the plastic pipe on the side of the airbox that didn't make much to me). Last week I also had the oil replaced.
Does anyone have an idea what could cause this intermittent issue with a temporary elevated RPM?
Thank you in advance!
Greetings,
Hans
Greetings,
Hans
