Torque Converter Clutch Concerns: Cycling/Shudder/Chatter Possible Component Reference/Action
242 ?ELECTRICAL ROUTINE
Powertrain Control System
Electrical inputs/outputs, vehicle wiring harnesses, internal transmission wiring harnesses, powertrain control module, TCC, TR, BOO, TP, RPM
Perform TCC tests. Run on-board diagnostics. Refer to Powertrain Control/Emissions Diagnosis Manual for diagnosis. Using Rotunda Transmission Tester 007-0085C and Rotunda Transmission Range (TR) Sensor Adapter ("MLPS" Manual Lever Position Sensor Adapter) 007-0086A or equivalents, perform transmission static and dynamic tests. Perform the following Pinpoint Tests: C, D. Service as required. Clear codes, road test and rerun on-board diagnostics.
Speed control equipped vehicles
Evaluate with speed control off.
342 ?HYDRAULIC/MECHANICAL ROUTINE
Fluid
Fluid contaminated
Inspect fluid for contamination. If contaminated, locate source of contamination. If burnt, inspect mechanical band, clutches. Service as required.
Main Control Assembly
Bolt out of torque specification
Retorque to specification.
Gasket damaged, off location
Inspect and replace gasket.
Separator plate damaged
Inspect for damage, service as required.
TCC, solenoid stuck, damaged, O-ring damaged or out of bore
Inspect for damage, perform solenoid function test as listed in electrical routine. Service as required.
TCC solenoid and valve (200), converter clutch control valve (201), thermostat bypass valve/cooler limit valve (216), spring, damaged, missing, misassembled, stuck, bore damaged
Inspect for damage. If damaged, replace main control. If parts are missing, replace missing parts or main control. If misassembled, reassemble properly. Do not stone, file or sand valves. This will remove the anodized finish and may result in further main control or transmission damage.
Pump Assembly
Bolts out of torque specification
Retorque bolts to specification.
Cross leaks
Inspect for damage. Service as required.
Front pump seal damage
Seal on inner pump gear damaged
Torque Converter Assembly
End clearance (excessive), internal leakage, clutch material damage
Perform end play check. Inspect and service as required.
