rubbing sound on my back end :) | Ford Explorer Forums
Texasplorer
Austin, Tx
X'ing 4x4
rubbing sound on Explorer's back end :)
I notice when I go over an bump something in the rear-end has like a noise that has a rubbing sound to it. Its on the passanger side and I checked if my tires are hitting the fender wells and it looks like it is not.
I am thinking it might be the leafs worn out b/c I pull and 2800lbs boat around a bit. What'cha all think? Does anyone else have this same problem?
If so, should I get like Add A Leaf or new leafs?
I did just put on new shocks on it about 7 or so months ago.
What year do you have? Do you have the stock size tire on or are they bigger?
its an 1996 EB
Stock size tires are on it.
