Running into a Firewall need some expert help | Ford Explorer Forums
HotCtyPlaya
Jamesburg, NJ
'98 Durango SLT
Hey i am doing the wiring part of the setup in my 98 Durango and I need some expert help. If anyone has done an install or knows what it takes. I am tryin to run the power line from my battery and there does not seem to be an open hole nor a hole in which I can fit this beautiful 0 gauge wire through. Need to know from anybody that has done it before if Im goin to have to drill my own hole or if I am missing something....thanks
Might as well just drill your own hole, just make sure you use a grommit in there.
and also prime the bare matal and once the grommet and wire are in place hit it with some scillicon.
Try this, pull one wheel off and look behind the fender liner. Remember to look at both sides so you aren't drilling into something important.
I'd definitely google around for some Durango forums and do a search there. I'd be really suprised if you didn't find a howto.
Look for a grommet that the parking brake runs through. Not sure about Dodges, but most trucks have places in the fire wall for running wires.
