1998Explodasport
- July 7, 2009
- Brockton, Ma
- 2001 Explorer Sport
Also I forgot to add that when it sputters and is about to stall it backfires too.
I don't have much history on this truck, I just bought it. It's a 2001 SOHC 2 door Sport. I just replaced the plugs with Iridium plugs, swapped MAF with a known working MAF, new air filter, fuel filter etc. Fuel pressure is at about 60psi, I thought it was high until I checked and I guess it's normal. After running the truck for 5-10 mins. it will lose alot of power and if I press the gas it will eventually stall. I looked under the truck and I noticed the cats were glowing red. If I shut the truck off for a few minutes and start it back up it will run fine for a few minutes and then do the same.
Just want to add that there is no codes at all, no pending or trouble codes.
