I have a 97 Explorer w/4.0 SOHC.
The check engine light is on and comes back on within a day if it is reset.
The truck runs really rough when it is first started. The colder it is, the worse it runs (almost stalls).
There is a loud clatter coming from within the engine when it is first started that goes away gradually within a minute, almost sounds like a bad exhaust leak.
When I diagnose the computer (Using a friend's Snap-On diagnostic equipment) and run the self-tests, I get no error codes except for the ones that are stored in memory. These errors tell me that both banks of the exhaust are running lean, according to the downstream O2 sensors.
I replaced both downstream O2 sensors, and this did not change anything.
Any comments or suggestions would be greatly appreciated!
Thanks, Erik
Thanks, Erik
