crimsonball '04
- December 12, 2017
- Leesburg,Fl
- 2004 Sport Trac XLT
Hey Guys,
I am a newbie here, so please be gentle......
I own a 2004 Sport Trac XLT 2WD with 47,000 original miles. Used to be the daily driver, but since retirement in 2010 it is seldom used. I noticed the left front corner noticeably lower than the right side. I believe that the front suspension set-up in this model is a torsion bar suspension. I slipped under the truck, and noticed that in the cross member that supports the tail of the tranny (where the trailing end of the torsion bar is attached), the torsion bar is mounted on a cam-shaped carrier that has a long tail that rests on top of a galvanized bolt that holds it in place. Are these things adjustable? The cam shaped carrier sits in a base and I can see a rust line where it moved about 1/4 inch from the original position. Once again, can you adjust the torsion tension by moving (rotate) the cam with the galvanized bolt? Will this adjustment raise the left corner of the truck?
Thanks guys........
Thanks guys........
