Sagging Rear End | Ford Explorer Forums
Sagging Rear End
Keach
San Antonio, TX
98 xlt 4x4
I know you've answered this a thousand times, but as usual i need help. My 98 4dr 4x4 seems to ride lower in the rear. I added edelbrock shocks but i don't think this has any effect. If you no whats up, please help me with a safe, secure fix.
Keach
98 XLT 4X4 SOHC
Edelbrock Shocks
Granatelli MassAirFlowSensor
Kurtz Kustom AirFilterKit
Im in the same hole as you Keach, but I cant understand why you have the problem alread in life. I have a 93 and it the sag has gotten MUCH worse in the past year. As far as a solution goes think about addig an ADD-A-LEAF you can add up to a 2.5" add a leaf and dependign on how far your sag is, you will fix it. Also by addign that add a leaf you can do a Torsion Twist, to raise the front end up the tiny bit that you need to, that is in order to make the truck sit level, or close to it.
Nick
'93 XLT 4 Door 4x4
Bosch Plat+4's with SplitFire Dual Core wires and a
K&N Air Filter with a Modified Air Box
My '99 4x4 sagged straight from the factory brand new. Many (most?) Explorers do. I have a theory that the newer 4x4s all use the "B" torsion bars which make the front sit a little higher since they do not "give" as much as the weaker torsion bars.
You have three choices:
1) the add-a-leaf that was already mentioned ($$)
2) if you do not want the stiffer ride of an add-a-leaf, longer shackles in the rear to raise it up a little (cheaper cost too)
3) a reverse torsion twist to lower the front down to match the back (free)
Hope this helps.
Gerald
[This message has been edited by GJarrett (edited 02-03-2000).]
I am assuming that you have already acquired this sag because you may do some lite hauling. Unfortunately the leafs on Explorers were simply designed for comfort, and thus, over time sag causing the back end to bottom out easily (There goes the idea of comfort)! It is hard to find add-a-leafs for Explorers, but I managed to find one after send an e-mail to Explorer Pro Comp:
"I was wondering if you made an add-a-leaf for the 1995- present Ford
Explorer that would increase ride height by about 1.5-2 inches."
I received a response stating:
"Try our part # 13120. That should be exactly what you are looking for."
The disadvantage to shackles is that they do not increase load capacity, body roll, or correct the problem of the sag. Add-a-leaf's on the other hand increase load and tow capacity, decrease body roll making the vehicle more stable on the road, and correct the sag as well, so the add-a-leaf is probably the safer alternative. From what I have read, the Explorer Pro Comp add-a-leafs do not radically change your stock suspension, other than the fact that they increase ride height 1.5-2 inches, which is exactly what shackles would do. Except with shackles, you are increasing the vehicle's center of gravity, but not making it more stable with a slightly stiffer suspension. And as far as price, they are not that expensive: I have seen them advertised for $25.00 at Summit (www.summitracing.com). That's not expensive at all. You may need to tweek your torsion bars a little bit, which you would have to do whether you go with shackles or add-a-leaf's. Just put the add-a-leafs on and just adjust the bars until the truck sits level. I am planning on going the add-a-leaf route (If it's not too obvious). Another thing that people have been unhappy about with the shackles is the fact that they hang out of the back end and create a visual eye soar. The reason that shackles are so heavily mentioned and used as an option is because they were the first item found to lift the rear for the torsion lift. Not many people knew where or how to find add-a-leaf's. I looked for months without being able to find add-a-leaf's until I contacted Explorer Pro Comp. I haven't used them myself, nor do I know anyone who has, but add-a-leafs have been used for a long time to lift and/or strenghten rear suspension. I hope this information has helped!
P.S. I apologize to anyone I offended with my criticism of shackle because I know a lot of you have gone this route! Dead Link Removed
Tim Y.
1996 Ford Explorer
Hey everyone! It's been a while since I've spent any sort of time browsing around here, so I thought I'd say hi and jump into this thread.
As GJarrett mentioned the add-a-leaf will solve the rear sag problem that is common on most Explorers. The suspension shop that made and installed mine compensated for the sag when putting the full length add-a-leafs in as my driver side sat a bit lower than the passenger side in the rear. (Fuel tank runs along the driver side, most likely cause for this)
Also for the late model owners, adjusting your torsion bars will easily correct any height discrepancies.
Nice to be posting again, talk to you all later.
Cheers,
Andrew B.
1996 Ford Explorer 4x4 (slightly modified)
BC, Canada
