saging rear | Ford Explorer Forums
saging rear
KYLE2289
MARTINSVILLE INDIANA
1994 FORD EXPLORER XLT
ordered new leaf springs from lmc and did the add a leaf when I put my lift kit on. not sure what went wrong but I have this rear sag across the back. the front measures 39 inches on flat ground from ground to the center of bottom fender well and in the rear I am getting about 35 inches or so on both sides. I was thinking of doing an soa. would that adjust the problem and level me out. or is there something I am missing or did wrong. thanks for the help.
What did you use for the front lift? My guess is you just have more lift up front than the rear.... That is assuming the AAL is installed between the overload and the main spring pack. I've seen people put the AAL under the overload and that does nothing for lift.
As for SOA, well, that will give you 5" or more (usually more) depending on what you do to your leaf springs, what shackles you use and how you mount your spring perches...
~Mark
