Samgraybeard
- May 7, 2021
- Sydney Australia
- 2005 3 SE
Thanks for your reply, with my LandRover disco 3, I have an air bag suspension so I have air. One thing that I’m a bit puzzled with is when I pulled the tensioner from the rear timing chain, four days after the chain failed, it was still holding pressure when I tried to decompares it by hand it was impossible, there was no give no slack, it was pumped up tight, the only time it released was when I compressed it in the vice, is that normal?, or is there a blocked port?, under normal operation do these tensioners normally decompress when the motor is off, hence the need for a pre oiler. Can a faulty tensioner over tension a chain cartridge causing the cartridge to fail?.Its simple i just a empty paint ball co2 tank or just a o2 tank I installed some t fittings so I can have a pressure gauge
a Schrader valve for draining the tank or adding air
I used a brass t fitting on the engine oil pressure switch port for oil supply and the dash gauge
The 2-3 psi air is your spring the tank is 1qt
The solenoid is a one way valve so the Pressure can always enter the tank but can't get out till you press the button on the dash
Hold the button down till the gauge pops up then start
The high cold oil pressure will be forced into the tank compressing the air and ready for the next start
Works every time all the time
I have a 30sec time delay off relay $10 on Amazon connect it to key power
This makes it automated just by the turn of the key Which is mint
