Dennis J.A.A.
- December 26, 2021
- Location
- South/central Wisconsin - Janesville
- Orfordville
- 2017 Explorer Interceptor
I waited for a while to ask this question because by now you have played with it a few times. When the alarm goes off and you only have a few seconds to put the key in the ignition and reset it does this new key affect the operation of stopping the alarm?Well, no pictures for obvious reasons but I can tell you that it was much easier than I thought. All you have to do is remove cover underneath the steering column and reach in under the dash and pull wiring loom going to the ignition switch. Remove electrical tape - there are a few wires there. I ended up cutting and splicing the thick (I believe it was green with red stripe) wire (test with tester to see which wire sends juice to the ignition) and just hook it up to a switch hidden somewhere either under the dash or in the glove compartment or even in plain site. After that you can put the wiring loom back together, put some black, electrical tape over it so it looks just like another bunch of wires under the dash. I did use one of the Chicago Lock keyed switches. You can mount it even in plain site but in a way that it could not be tempered with or have wiring easily accessible. Nobody will know what it's for anyway but you. Switch like the one in the photo. Hope that helps.
