bigdaveakers
- June 27, 2007
- UK
It no worky
So I have been out with the spanners this morning and don some testing. I have attached a diagram to help explain what I have done and hopefully someone will be able to help.
Now I have had the compressor out and tested it on the bench, it works but I have never heard it run on the car. I loosened the linkage on the height sensor and manually moved it up and down, this resulted in the solenoid clicking so that works. I have opened and closed all doors in all combinations and still nothing from the compressor, tried to reset the system by simulating jacking the car up (manually moving the sensor) and still nothing.
So can anyone tell me what the cylindrical dvice next to the compressor is and what the electrical connections to it do?
Also does anyone know where the fuse is for the compressor? It seems that I am getting no power to it and thought it may be an easy thing to eliminate but short of pulling all the fuses I dont know which one it is- The system is expecting to work as evidenced by the warning light coming on after 10-15 mins of driving.
Any suggestions would be much appreciated, along with any bits of the system I am missing (is there a control module?). At the end of the day I dont really need to levelling system but it would be nice to get it working!
Cheers in advance!
Cheers in advance!
