service engine light. | Ford Explorer Forums
ICUFFEM
Crest Hill, Illinois
2008 Explorer XLT 4.0
my 04 ex 4.6 started running rough about a week ago. the service engine light popped on and stayed on for a few days then went out and came back on. The truck runs rough (misfire) and when I took it to autozone they said I had a code for the crankshaft positioning sensor and a misfire on cyl. #8. could the misfire be causing the code for the crank sensor or vise versa? Is the crank sensor hard to replace or could it be the coil on cyl. 8?
crank sensor is about 14 dollars and its not too hard on the v6. on the v8 it might be a bit more tight.
