service the injectors or buy reconditioned ones? | Ford Explorer Forums
fabianoliver
Montevideo - Uruguay
1994 XLT
Hello all.
Well, i've my new explorer xlt 1994 from some days ago, and i was thinking about injectors.
The truck is running ok ( is my first explorer so i cannot compare the ride with another good one), but the plan after the main repairs is have the injectors at top condition...
Whay can be the best way, unmount the ones on the truck, do a pro ultrasonic clean put new o rings, or buy a new set of refurbished oem ones? ( it doesn't seems too expensive)...
thanks for your opinions.
fabian
If the motor is running ok right now, then cleaning your existing injectors will probably be fine. If they are badly clogged, the refurbished ones will be the best route.
I vote bench clean them
Also consider cleaning your mass air flow sensor and replace your 1994 oxygen sensors, they get lazy with age.
I consider this part of a major tune up when the trucks get this old.
Thanks for the replies, the X is running ok , so I’ll send them clean as you suggest.
I’ll see if I can find filter parts here…
